bobavett
- Joined
- Oct 1, 2007
- Messages
- 65
- Location
- PERTH, WESTERN AUSTRALIA
- Corvette
- 1986 C4 AUTO Torch Red Tan & Black Interior Coupe
Hi all ....
The good news ..... I am 90 % done with my restoration ..... interior, paint, weather seals, electrics etc ......
Now the bad ..... when I press the accelerator the throttle does not go back to it's original position .... causing high reving ..... it appears to 'get stuck' and needs to be helped be putting your foot under the accelerator (don't worry only in park and not on the road) .... with the bonnet up you see it goes back to its original position .....
I have inspected the throttle body and its clean ..... I used WD40 on the external spring and throttle mechanism ...... NOTHING ! :confused
Could the spring mechanism be at fault or could even the accelerator cable be stretched ????
I am hoping someone has experienced a similar problem and has a fix for it?
Thank you all in advance
