throttle spring tension
  • Thread starter Thread starter Robin7TFour
R
Robin7TFour
hello all,
i think the throttle spring(s) are too stiff on my motor. can someoen measure the pull tension. i am guessing a fish weight gauge would do the trick.
thanks in advance
Robin
Are you sure they are in the right position. I noticed on a buddies '67 that he had the return spring on the carb to the rear of the motor when it should have been on the carb to the front of the motor. It was the wrong spring to start with and stretched too much. For your year, I'm not sure of the correct positioning, but I'd verify you have it right.
hello, i am using a custom spring mount on the front of the intake manifold. the spring(s) go towards the rear(carb).
robin
