Throttle valve misfit?
Peer81
Netherlands
'81 Black
Hello everybody.
Problem with my carb. Could not get it idle under 700 rpm (with the idle screw compleetly out). First idea, vacuum leak somewhere. So with a vacuum meter I checked my new vacuumlines. No problems there. Next I found was 1 bolt hole in the intake (right side beside the egr) had almost no thread in it. So bought a recoil set and recould the hole.
Next I found the throttle blades had more play inside the throttlebody then I thought. (I already rebuild this carb so put bushings in the throttle shaft openings.) These blades came from another body because I alsready knive edged these blades. Now I think maybe the original blades will fit this body better or is this normal?
I would like to know what you think :)
Greetings Peter
Send the pictures and your questions to v8fastcars@msn.com
If Lars can't answer a Q-jet question, it's not possible with a Q-jet.
Hello Tim,
Your absolutely right, why didn't I think of that.
But I had some time left yesterday so first I loosened up all the little screws and repositioned the blades. Now I lookes a lot better. While I was at it I replaced a edged blade for a normal one and I didn't see any improvement. So I'll test it again and see if it's doing any better. :)
Greetings Peter
I would think about maybe a touch of loctite on the screws too. Be a bummer to have one shake out. I've seen some carbs those screws were staked to prevent them from coming out.
