Nate,
There are several threads concerning vacuum leaks throughout this site, but the following link will get you in touch with the L81 Registry:
L81 Vette Registry Forum - Corvette Action Center - Corvette Forum : CorvetteActionCenter.com Corvette Forums
Concerning vacuum leaks, yes, it could be anything in the engine bay and even the headlight switch inside the cabin. The best way is by using a vacuum pump (and they have a gauge attached to them). However, due to temperature in the engine compartment over a long period of time, the plastic connectors also suffer from heat and become brittle.
1) Spray WD-40 or similar product on the hose ends and fittings before attempting to disconnect the hose segment.
2) Follow the emission's label and start with those hose segments to check for vacuum leaks. Cap/plug the opposite end of hose being tested. Remember that perhaps the opposite end of hose could be disconnected already (thus causing the vacuum leak).
3) Exercise extreme caution and care with solenoid connectors (passenger side and slightly forward of distributor). Spray WD-40 to ease disconnection the hose segments (do one at a time). Twist the hose segment to aid in breaking the seal or grip the hose segment has on the plastic fitting. The top solenoid one is red in color. The bottom one is white. THEY ARE NOT REPRODUCED, SO SLIGHTLY DIFFICULT TO FIND IN eBay.
4) with vacuum pump and other end of hose segment capped/plugged begin creating vacuum signal inside hose segment. If it does not build (like the needle move from 5 in-hg to 10 in-hg) AND does not hold the vacuum after you stop pumping, then there is something wrong with that hose segment.
5) you could try to get 4-5 foot segment of hose of each diameter of hose most common in the engine compartment, but I would only do that if I found a lot of the hoses dry-rotted.
6) after you have checked the emission's hoses, check the head light pop-up mechanism hoses. If the head lights are slow to rise, then you have a leak somewhere (it could be the actuator seals, which are not terribly bad to change, but not available locally -only specialty corvette parts supplier like Corvette Central, Mid-America Works, Ecklers, Corvette Doctor, ZIp, etc.
7) the rough operation could be your positive crankcase vent valve (PCV). If it is sticking open, it basically causes one serious vacuum leak.
Good luck.
