T
tluv327
As you guys might have read in an earlier post, my timing chain broke on my 327. Gear teeth were shredded off the crank gear, chain broke in two, etc...
Well, I replaced the gears and chain with a cloyes roller and put everything back in place. I started the engine and got lucky. BUT - the chain was hitting the timing chain cover. The gears were flush against the engine and everything went back into place just fine. WHY?!?!? The harmonic balancer has slight wear in the groove wear the crank key fits which makes it a tad bit sloppy but not enough to make the chain so out of whack where it would slap the cover, correct?
I took the cover off and the chain was still tight and appeared to be plumb. Any ideas please !!!!
