The above post is a bit limited in information
So...you have a stock short block and heads with a COMP Cam and an "RPM" manifold. Can you post the cam specs and more specifics of the intake manifold? Also, what do you have for exhaust?
As for the initial timing, the spark advance is controlled by the ECM so, I'd leave the initial timing at 6° BTDC.
