Hi New to the forum here have owned vettes for many years also new to the 81 Computer command control (CCC). 81 is in stock condition except egr valve removed. Carb is rebuilt and has new bosch o2 sensor. Vette will not pass emissions at idle but will pass at 2500 rpm. The problem I think is the timing. I set it at 6 btdc with est disconnected by the book. when I reconnect the est the timing goes to 26 btdc at idle. After a few minutes timing will go to 36 btdc idle. When I gas it the timing does not change till about 2500 rpm then jumps to 48btdc. The dwell is 30 degrees on the mcs. Idle is a little rough and hard to maintain a set idle. Drives great with no issues till you come back to idle which is not always the same rpm. Thanks Ed
