M
MrGibbly
I bought my 1978 L48 in October '03 and it has run pretty well since then. Up to this point I haven't done any engine work at all. Lately, it has gotten a little rough around the edges so I thought I'd take care of some simple stuff like plugs, wires, cap rotor, etc. Before I took anything apart I decided to check the timing but I'm having some trouble. I've never done this before so bare with me...
First, I disconnected the vacuum advance from the distributor and plugged the hose with a screw. Then I hooked up the timing light and fired her up. I found an angle where I could get a shot from between the radiator hose and the alternator that was clear. I had a very hard time finding a marking on the harmonic balancer and I couldn't get a reading. I gave up and crawled under the car (suck it in!) and smeared some spackling in the little groove in the harmonic balancer. That made it show up clear as day under the gun. However, the timing reading doesn't make any sense. When I start with the advance on the gun set at 0 the mark appears way at the "top" of the balancer. As I advance the dial on the light it works its way "down" until it is in the middle of the indicator affixed to the engine. The trouble is the light reads 46 degrees!!! Any help would be greatly appreciated.
