Hib Halverson
Do not improvise a damper removal tool.
Buy a harmonic damper/balancer removal tool intended for use with Chevrolet engines. Also, beware of what you buy. If you go to Autozone or Pep Boys and buy a cheap, Chinese-made tool, don't be surprised if it breaks or lasts only a few uses then fails.
Do not use a gear puller which grips the balancer on the outside rim. You'll damage or destroy the balancer during the attempted removal.
When reinstalling a balancer use a tool designed for installing harmonic balancers. DO NOT attempt to "press" the new balancer on using any kind of impact device.
Once the old balancer is removed, inspect the crankshaft snout for damage and to make sure the keyway and the key are in place and not damaged.
