S
steves1980
My timing was on 4BTC, when i got the car, i just got around to checking it set it on 6 like it says to, the reson i wanted to check it was after it sits for say 10 mins. when i go to start it again, it lags, a little , like one does when the timing is off, i guess lag is the word for it, it starts fine when cold, i have played with it set it @ diff. sittings still does it, i dont think its a bad spot in the starter, as it would do it when it was cold if is was in the bad spot, it seems to run fine, is there a better sitting then 6 BTC ? it has 27,900 miles on her, so i dont think it would be any wore out parts, what do you all think ? leave it @ 6 BTC or change it , looks like i will never get this lag out its no big deal, i did notice it does it worse @ 6 then 4 BTC , it has all new tune up parts all GM parts , i put all GM stock parts back in it.
