WhalePirot
got it done.
I'd sure want to know if it demands replacement, b/c, as you are finding out, it is a PITA to do. I had to remove my throttle pedal to get to it, partially b/c I was changing to a shorter (post '84) cable for cosmetics with my TPI setup.Have a cable that is loose, the one that goes into the firewall behind the brake booster and assume that its the accelerator cable. I've taken out the seat and bottom dash panel (drivers side) and still can't get to the top of the accelerator pedal to see if there is anything loose or broken. Can't figure out how to access it. Any help here! Thanks in advance.
