R
rpounds
I know this subject has been covered in earlier threads . . . at least to some degree. On my '75 coupe, I have a basically stock tire size (as far as the height). However, they do not fill out the wheel well as much as I would like. Does anyone have experience (good or bad) with going to a taller tire? Can anyone help determine what the max diameter would be without problems? I can whip out a tape measure and come up with an approximate diameter. However, I really don't want to go with "trial and error". That has a tendency to get a little expensive. So, if you possess empirical data that would help, I would appreciate it.
Thanks in advance.
Ron
Thanks in advance.
Ron
