mr1960
- Joined
- Jul 2, 2004
- Messages
- 14
- Location
- Cypress, TX
- Corvette
- 2005 Victory Red Coupe & 2005 Black Coupe
What is the correct tire pressue for the Goodyear EMT's that come standard on the 2003? The Chevy place said 40 psi.
Steve,Ctfoodguy2000 said:Just make sure you check the psi with a "cold" tire.
A lot of things can vary the temperature when the tires warm up. In your example I would say the sun is shining on the right side tires increasing their temp, which in turn increased the pressure by 1 psi.Ctfoodguy2000 said:HI Remo:
The part that confuses me is when they all are at 30 psi cold ......the the lf is 32, rf is 33, rr is 33 and lr is 32 after driving! :confused
Agreed. Mine behaves in much the same way. I don't think it has anything to do with one side in the sun, more tire friction on one than the other or whatever, I think it's just the nature of the beast.Ctfoodguy2000 said:HI Remo:
bluecoupe said:Just because the sensors cost $100 bucks each doesn't mean they are more accurate than a $20 dollar hand held. The $20 dollar unit doesn't have to be bolted to a wheel and bounce down the highway. It also doesnt have to transmit readings to a computer. I trust my high quality hand held guage for accurate initial readings.![]()
