JBsC5
Titanium Coils Springs for C6
Timet (sp) maker of the Z06's titanium exhaust is hoping to supply titanium coil springs for the General.
75% less weight than steel springs..with smaller packaging requirements..
Titanium is 43 percent less dense than steel but just as strong. Its highly resistant to corrosion. It can be cast, machined and stamped.
Standard steel costs about 35 cents a pound. The high strength steel costs about a buck a pound. The alloys used in jet engines cost roughly 15 to 25 dollars a pound. Even a grade of titanium suitable for mufflers costs about $10 a pound.
As far back as July 2000, timet, the supplier for the titanium used in the Corvettes mufflers is on record as stating ..they are hoping to supply titanium springs to GM.
They state that because of the materials strength and stiffness, titanium springs require less wire than steel ones, which conbine with the lower density to weigh as much as 75% less than a steel spring.
Would this be a better setup than the present leafs in the C5?
If so Y?
If so Y?
