D
Da Hawaiian Punch
Aloha!! I'll make this fast. When I turn on the air con, the secondary fan does not turn on, I checked the relay by going through the same passeger as you would when pulling a code from the computer, stick the jumper wire in, turn ignition on with out the car running, and both the fans do come on, they seem to be fine, the primary does work when it's supposed to though, can you help me please? Much Mahalo to you!!
