- Thread starter
- #21
U
UKPaul
I'm probably a bit late for this post but I'll reply anyway!
You definately need the stock type rad with inbuilt trans fluid cooler. Period. I've fitted A BTO 200-4r in my '81. When I fitted the OD unit I also fitted a trans temp fluid guage. It's quite revealing. With the stock cooling system (new rad fitted) I found that the ideal trans temp of 150 deg was being slightly exceeded when in OD with the converter locked. If I ran in OD with the converter unlocked, or used one of the lower gears, the fluid temp rapidly climbed & kept climbing. A lot. I fitted a small external cooler in the return line to the tranny coming from the rad. The rad will now help to warm up the tranny fluid quickly from cold & then do it's normal job of cooling the fluid. The cooled fluid then passes through the external cooler & goes back to the trans. We haven't got Texas weather here, but I did some testing on a day where the ambient hit 100F here. Testing involved lots of WOT runs & everything I could do to increase the temps. What I found was that the tranny temp was running, as usual, about 130 when in OD with the converter locked, & was just above 150 (the ideal temp) when cruising in any other gear. I'd taken the entire A/C system out the previous winter (not expecting a record breaking summer!) so cooling will be more efficient due to no condenser in front of the rad. Really I should have got the smallest external cooler I could have as it's slightly overcooling it now. Fitting a large cooler could mean that you'll end up running it at to low a temp. A temp guage is very well worth fitting. And another bonus of the external cooler is that the coolant temp always stays at 180 (the stat rating) & I've never got it near, let alone above, the 200 mark. Prior to fitting the external tranny cooler my coolant temp was normally 200 or above (with both the th350C & 200-4r). But I mention this to people & they look at me like I'm crazy.......
Any reason you're going for a 700-r rather than a 200???
Cheers
Cheers
