T
tscott9330
Alright, I hve a question. Actually, a few questions.
1. What is the highest compression ratio you can run a set of Iron heads at on pump gas with out detonation?
2. whats the highest compression ratio you can run a set of aftermarket aluminum heads on pump gas?
3. If I am shooting for a compression ratio of around 10:1 (possibly a little higher) could I go with a set of aluminum corvette heads on pump gas?
The reason for question 3, is i just read a book on getting power on a budget and it mentions corvette aluminum heads as a good high compression, and comparitivly low cost alternative to a set of aftermarket aluminum heads, is this true?
Is there anyone out there running this set up? If so how does it work in a daily driven application?
I JUST WANT TO DO MY HOME WORK BEFORE I SPRING FOR A SET OF PRICEY AFTERMARKET HEADS.
Tom Scott
Tom Scott
