Your right!!!! I was Thinking back-wards for some reason,Dah!!The inside wheel while turning has a tighter radius to follow and if anything should look like 'toe out', not 'in'
I think Brian isn't familiar with the terminology.
Brian, can you describe in more detail what you're seeing with the steering wheel turned fully to the right that looks unusual?
Brian,
That is an effect of Camber and Caster.
Camber (positive camber) is when the top of the wheel is closer to the car than the bottom, when driving straight forward.
Caster is the angle of the steering axis, when looking from the side. Think of a chopper motorcycle. When you are driving straight, the front wheel is vertical but when you turn, the wheel is tilted.
Toe (toe in) is when looking from above the car, the front left wheel is steering to the right, and the front right wheel is steering to the left.
http://www.ozebiz.com.au/racetech/theory/align.html
Certainly, Loose w/b's, bad ball joints,bad control arm bushings,bent control arm, bent spindle,bent frame or just bad alignment!!Can negative camber be caused by bad wheel bearings or ball joints?
...Does the steering feel odd when you drive the car?
If the front end is so out of alignment that it looks strange with the eye, then I think you would notice this when you drive the car.
I agree. If you're too far out, you'd feel it. Take the car to any competent alignment shop and let them have a look at it. They'll be able to answer all your questions in no time and do the alignment if it's needed.
