norvalwilhelm
I have been working on my cage and this is the tube bender I am using. There is a big difference between a pipe bender and a tube bender. A pipe bender is the type that looks partly like a press and uses a die on a jack to bend the pipe up in the middle. This will not work for roll cages.
A tube bender grabs the tube and pulls it around a die with a guideing/supporting shoe.
This unit runs on a combination of shop air and hydraulic pressure. The shop air plugs into the hydraulic pack and uses it to produce 10,000 psi of hydraulic pressure. That is the yellow pack to the left.
The orange cylinder applies the pressure to the die. Each pipe size requires it own die and supporting shoe.
This is another shot with the pipe being pulled around the die.
This is the roll bar bolted in after welding for a test fit before adding the back bracing.
This is a homemade belt sander and 14 inch vertical disk. While not needed it really makes deburring and flattening cut edges easy
If anyone is interest I would start a post teaching others how to accurately use a tube bender. I expect and get 1/16 and better accuracy but you have to know your particular tube bender.
Anyone interested? I would start another post on how to learn your tube bender and some tips on how to make a better cage.
