H
hooks
Need help removing inner cover on my 1993. The fabric is drooped and i need to fix it. What is the best way to remove this fabric?
I need to claify my question---i want to remove the whole thing--pad & the material--does it just pry off? If so what holds it back on?If it doesn't peel off easily try using a heat gun. The only glue I found that works to put it back on is 3M.
