Jim D
Whats involved in removing the top plenum on my 87. I"m going to replace the injectors, thanks Jim.
Just finishing up mine....As stated above pretty straight forward deal, You'll need
a Torx40 socket and extension to reach the above mentioned 2 "Hidden" bolt's
and it would be a GOOD idea to change that Thermostat while ya got that Plenum off!
I had a Bad EGR Valve, so that got changed along with all the other sensor's under or near that plenum as a preventative measure, I'd HATE to go back in there a month from NOW because the T-Stat went BAD when ya "COULD" have changed it NOW!!
I also changed the water Pump as my car hit the 70K mark and at 20 Year's old
I figured it had done it's duty!!![]()
All back together.... "WHY" did I run the Plug Wires over the Valve cover's your Wondering??....
I am going to attemp to replace the injectors myself and am reading as many threads as possible to build confidence, since I haven't done this before but just one question........I read about relieving the fuel pressure and how to do that but then I read about disconnecting coolant hoses and lines and wonder if the radiator should be drained prior to starting the project. Any help here??
