Chad,
I had a small leak on the driver side top corner of my windshield and I wanted to correct the leak and also paint the molding to look new again. I asked several local's how to remove the molding and even bought a tool for removing it. I removed the side pilar molding first and then tried this tool, well it didn't work the way it was explained to me. So, I decided to go it on my own and was able to locate the location of each clip and all I did was lift the molding up by inserting the tool on the lower edge of the trim and lifting. I started at one side and worked across the top to the other side. I had no problem with it and it went back on after painting and looks new.
Maybe one of the other members has a better explination. Hope this helps.
Tifton81
