Jack
- Joined
- Dec 27, 2000
- Messages
- 1,825
- Location
- Florence, SC (Timmonsville SC)
- Corvette
- 71 War Bonnet Yellow VERT 71 BH Blue CPE (SOLD)
Got 2 questions folks ... need torque specs:
Mine is a 71 L-48 (lo-po 350) with TH400 auto trans ... mine Does Not have u-bolts where u-joints attach to diffential stubs ... mine has 2 caps & 4 cap screws/bolts per side.
What is the torque spec for the u-joint cap screws/bolts at the differential side (Inner stubs)?
What is the torque spec for the cap screws/bolts that hold the outer u-joint flange to the Outer axle stub (flange that has the french locks)?
I'm rebuilding entire front suspension (urethane), part of rear suspension ... stroker-motor's rotating assembly went out for balancing today.
Thanks!
JACK:gap
Thanks!
JACK:gap
