mad
here is the only possible problem i see with your recomendation......as you know combinations have to work together in order to increase performance...if something in the combination dosent match with everything else you have done,it could actually hurt the cars performance....and converters are a good example of it..these mass produced converters are made using a stock corvette"s specs.....but lets say vettefan,when he rebuilds his motor,decides to change cams,or changes cylinder head combos,injector and throttle bore sizes or rear end ratio etc..etc...then a mass produced converter that uses general corvette specs when its built,will actually not do him any favors........even your car for example...you have a 2.59 rear ratio with 285/40/17,which are not the stock overall diameter...these 2 factors alone could greatly affect how the mass produced converter you have performs.........when you have a converter built for your application...here are the most important questions they will ask.....vehicle weight[most vets weigh about the same/except for the drivers weight so not an issue vs mass produced converter]........engine size/bore/stroke[not an issue if stock,but if you bored yours out or dropped a stroker motor in,it will make a big change from factory specs and performance]....type of cylinder head and induction[as you know cylinder head work,injector and throttle bore size can greatly affect performance/torque of motor vs oe]........lift and duration of cam as well as duration at .050[not an issue if stock,but what if vetfan when rebuilding his motor makes a cam change that is far different than oe,that changes the whole ballgame as far as converter stall/lockup].....rear end gear ratio[major factor for stall speed...mad,you have 2.59..what if vetfan has a 3.08 or lower...thats a totally different animal than your car then]....overall tire diameter[this affects overall gear ratio...mad,you have a tall tire[285/40/17] on the rear,which is taller than your 87 had oe and is actually going to affect your 2.59 ratio so its even higher than if you had 255/50/16 etc..major factor in determining converter stall/performance]..........so i guess what i am trying to say is,i bet alot of corvette drivers on this site are seeing alot less performance out of their vets then they actually should...reason??,not thinking out their combinations and just throwing performance parts on their car that might work on joe blows car the next town over,but actually hurt the performance of their own car........so my opinion vetfan...if you are leaving everything bone stock then the mass produced converters will work perfect...but if you are changing induction/camshafts/rear end ratios/overall tire diameters etc...then call a good converter shop and have it custom built to your combination......just my opinion.
