torque specifications 1966/327
paul robb
AZ
1966 silver pearl coupe
Could someone please give me the torque specifications for the oil pan and the transmission pan. None of my books give this information.
THANK YOU IN ADVANCE. PAUL
:confused
Torque specs
:confused
Oil pan 65 to 80 inch bls. or 6 to 8 foot lbs.
Tran pan 12 foot bls.
Jack
Now i can get started today !
What kind of jobs are you doing
Hi , you sound excited about starting a job, what are you doing that requires the info you needed? It will give members on the forum a heads up if you need further assistance.
Jack
Jack
Jack, The transmission pan gasket is leaking and needs to be changed.
I bought the filter kit and with the weather being fairly good i thought i would get started. Not really excited about it,buts needs to be done.
Just wanted to get the torque spec's because i have a habit to tighten
things a half turn to much and breaking them. Torque for the oil pan is a
just a need to know thing.
We have all been there
Less is better with oil and transmission pans, good luck
Jack
