MFPvette80
I've just adjusted the timing on my 1980 (350 SB) to around 10 degrees BTDC at idle with vac adv. off and plugged. This is higher than the factory setting of 6 degrees, but with the RV cam it seems to run better with no pinging. I remember reading somewhere that the "total" advance for a SBC should be about 36 degrees BTDC. With the vac adv. on and running at 3000 RPM I'm seeing around 50 Degrees BTDC. Should I set the timing at total (high speed) or at idle? Do I have a bigger problem in my HEI distributor?
