dsharp
I need to get a 97 with some front suspension issues (front tranverse spring broken?) to a suspension shop about 35 miles away. It is pretty flat and I can stay on back roads. Is it ok to use a 2 wheel dolly? It has a 6 speed.
I can't see in any mechanical way that could be possible!~!!It is also not good for the clutch pilot bushing.
:eyeroleIf you do use a dolly be careful and drive slower than normal.
Being a manual trans, throw it neutral and off you go.
:eyerole
NO , DO NOT DO THIS
Instead of just saying "Don't do it", tell us the reason, especially when there are differing opinions.well .....GO AHEAD AND LET US KNOW HOW IT WORKS OUT , it's not my car.....
In my previous post to this one, I mention that normally the output shaft of the transmission has a gear that falls below the oil fill line and draws up oil for lubrication. This lubrication is for the output shaft.Here's a thought, as you said the differential is splash lubricated as is the manual transmission. Tell me when is the differential ever in neutral. When the transmission is in neutral are the gears turning, if so why?
