Hijinx here on the site just bought one a while back, and I don't think he is going to use it now. You might get with him and see. I think it is even powder coated for really great looks.
This topic comes up often, and it is important to determine exaclty what you are after and what kind of budget you have.
The only problem I see with a stock, or stock style TPI is that you are limited on upper end hp by the nature of the design. By the time you start to mod it to get more air flow and more custom variations in the tuning, etc. you could have bought a complete stand alone EFI system that has better high end flow characteristics. However, for good strong torque, good reliable running, great looks, and ease of diagnostics, etc. you can't beat the stock TPI systems.
I would agree with what has been said here. Try to stick to newer than 85 systems. The best really are the 88 and up. All the runners and intakes are the same size for a 305 or 350 TPI system, it is the size of the injectors that makes the difference.
Check with Hijinx on his system, and if no deal for you there, go to the swap meets, etc and try to pick up a intake only (distributor would be nice as well) for $250 or less. Call up Summit racing and get a set of the accel/ford injectors coming to you. Get an adjustable fuel pressure regulator from
www.tpis.com or anyone you want. Go to Painless, Street and Performance, TPIS, Howell, etc. etc. and get a stand alone harness and you can get a computer at any autoparts store. Just specifiy in this whole thing speed density or MAF. Finally, get with -=Jeff=- here as he can work with you on burning a chip and he has good experience with them.
Now, plumb your air intake, fuel lines, mount your high pressure pump and run a new feed line......and you just about have it.
Or, call Summit, Tpis, etc. and order a complete EFI system in the box with everything at one time and have it installed in a weekend.
You have many choices, and they are all great just depending on your budget, time, and performace desires.
