8
81LT4
ON monday, I decided to port the front of my plenium, on my 91 l98 man did i feel a difference, the car felt alot stronger, I ran it for about 3miles and no ploblems, got home and played with
it a bit more just to make sure i did not forget anything. I did
not mess with any sensors, I also bypass my water heater.
I cleaned my throttle body,and left my tps alone.
the next day, as i got in it to go to work, I felt the rpm raise
then lower, this happened for about 10 seconds. Now the
car sits at 1800 rpm, and wont come down. I drilled out
the little cap GM puts on the TB for ajustment to the rpm
even when i release the screw as far back as it will go the RPM
does not lower. this is as far as i've gone, no other ajustments
have been made. Has anyone ever had this happen?
PS. I reused the runner gasket,and put a new TB gasket.
