the TPI unit is designed for torque on a 350 and in stock form is supposed to run out of steam at 4500 a stock 400 would probably be OK but if it is modified you would need large tube runners and some port work to get the power you want. I have seen TPI's on 400's in magazines and shows, but don't know firsthand how they run. I have a modified unit on a 383, but the engine was built for TPI the cam is designed for TPI use I have brodix heads and the runners are shortened siamesed which brings the power band up to 5500. my reserve is 250 which would get you fuel rails with injecters and regulater, baseplate, runners, throttlebody, air control motor, Throttle position sensor and stock bolts you will need to purchase a computer and wire harness and fuel delivery and return system gaskets and O rings throttle cable(87 vette in mine)
I am also an "old carburator guy" but the TPI install is not hard, the hardest thing is running the extra fuel line. I used the Holley Commander 950 for the electronics and their instructions were quite clear and tech support is excellent as I am sure most of the others are.
If your engine is modified I would suggest the Holley stealth ram system feel free to ask any questions.
Craig sr
