TPS and IAC setting problem (maybe)
I have been working through the "rough, surging idle" condition with a 1991 Corvette that I purchased recently. Car has 76,000 miles.
I had replaced the plugs, wires, distributor cap, rotor and two vacuum lines that were dried out. I also removed the throttle body and cleaned it and the IAC. With each thing I did the performance got a little better. However, the surge never went away and when I would let off the accelerator it would buck a little and when I stopped the car would sometimes idle down so far it would shut off.
I checked the TPS and it read about .36 and I got the code 22 a couple of times so I figure it must be bad as well and I replaced it today along with the pcv valve. Without any adjustment the car ran much better and the idle seemed pretty good. When warm there was a slight lope but not enough to change the rpms.
However, I could not leave well enough alone and I tried to set the minimum air flow and TPS. I put the car in diagnostic mode, waited the 30 seconds and then disconnected the IAC. I forgot to take the paper clip out before I started it and that may have something to do with what follows (or it may not). I could not keep the car idling long enough to set the minimum air flow. This the same thing that happened before the new TPS only it was much worse. There was a very distinct rich smell. After several attempts at restarting it and it dying I abandoned that and reconnected the IAC. I checked the TPS and .45 volts was as high as I could get. I could elongate the holes and gain more adjustment to get the .54 volts but I should not have to do that.
I restarted the car and drove it for about 15 minutes. Nearly every time I stopped it shut off and the rough idle is back. I checked for codes and got a 22 and a 45. I assume the 45 was related to the rich condition when I was trying to set the minimum air flow and the 22 was me fiddling with the TPS.
I need some guidance. Help!!
