T
TooTall
I have an issue with the traction control system on my 2000 vert. I am running 20" wheels all around and have always had an issue with traction control when on mid to high speed turns. Usually I go to competetive driving on the freeway with no problem.
Yesterday I was on a 2 lane road with some fairly sharp turns and the Active Handling feature came on. I would normally just turn the Active Handling button off and continue on. But this time I got a warning on the DIC :
Service Traction Sys & Service Active Handling
and the active Handling light is always on.
I pulled the following codes:
· C1217 BPMV Pump Motor Relay Contact CKT Open
· C1243 BPMV Pump Motor Stalled
Sounds like I have a bad Pump Motor.
Can anyone give me some insight and if this is something I can replace myself, like where is it and a part number.
