hoosierdaddy
Traction Control Function When To Use And When Not To Use!
Hib where would I find this? Is this the build sheet for the car? Or is it a label that would be on the car somewhere? Hey while I got you here do you have any idea why my HUD unit on the dash would be crooked; kind of like it slipped a little bit and shows that it is not seated right on the dash pad, shows a little gap on the right side like it is not quite in the groove on the dash pad. It works as designed but it is just a little irriatating that it is just a little crooked. Seems like a lot of work to remove the dash pad and etc. Is there any way of straightening this up without all of this or not? Most people probably would not even notice it, in fact I didn't until I bought the car and started cleaning the inside of the windshield, not a big deal just looked like it slipped a little. Like I said it works good and appears to be tight, doesn't move around or anything. Thought maybe you might know if there is anything that I can do short of taking the dash appart. :confused
Thanks,
Bill
Thanks,
Bill
Hib Halverson said:Gorgon is spot-on.
You also can tell if the car has Active Handling by looking on the RPO label for JL4
this cleared up quite a bit for me. When I get it out I will be able to tell if I have ACTIVE HANDLING by holding the traction control button down for what 5 seconds? Will this display a signal on the dash or DIC?
..I am going to rest now...my head hurts:L
