bucket
i need to pull a trailer,
<1000lbs.
is this going to be a problem?
(large smile)
<1000lbs.
(large smile)
Note: This feature currently requires accessing the site using the built-in Safari browser.
They make a hitch for the Vette, but you have to be careful towing something. 1000 lbs might be a bit much. I am planning on installing one and pulling one of those small motorcycle trailers on my 91 convert. I have seen them on other vettes but none towing anything large.
Reese makes a corvette hitch. They were a GM C4 option through 1995.
There was no factory option towing package during any model year of the C4 series.
The only time any Corvette was factory-equipped for towing was 77-81 when RPO ZN1 was available.
I would strongly advise not attempting to tow 1000 lbs with a C4. First, it's unlikely you'll find any aftermarket tow hitch which would be safe for towing that much weight.
The car's rear structure is not robust enough to take the loading, the car's cooling is marginal at best for towing and, if you load the car itself (driver, passenger and cargo) then hook-up the trailer, you'll be way over the car's GVW.
Lastly, and perhaps most importantly, since it's unlikely a 1000-lb trailer will have brakes, you'll be relying on the the car's brakes to stop the combination and that's really unsafe. The base brakes (ie: non-Z07/non-ZR1) on a 92 were barely adequate for just the car, alone, much less a car at GVW pulling a 1000-lb trailer.
Where did you find someone still making a hitch for a C4 ? about 4 yrs ago I looked for one and couldn't find any.
I ended up making my own.
I sent pictures and measurements to spanishvet when he needed one.
1000 lbs seems a little heavy but I do remember someone on CAC at one time pulling a small boat.You are talking less than 1/3 the car weight.
Glenn
Maybe mount the hitch on front and push the trailer. Anyway it was a long time ago but if I'm not mistaken my owners manual for 87 had a section on winter(snow )driving and I was thinking that there was something about towing was not recommended .Thats why I suggested checking the owners manual .
.as you can see, the hitch itself will go up to 2000lbs. so the structural integrity is not compromised..
Corvette Trailer Hitch, Class 1, 1984-1996
How much does the scooter weigh?
When you pull the trailer, will you also have two people in the car, full fuel and the cargo area full?
