D
Drastic Plastic
I'm a new owner of a 2007 C6 Convertible. I brought the car cross country. All is well except when I received the car there is a leak from the Trans cooling line connection to the Radiator/Cooler. When I got under the car I found a strange looking connector with a clip of sorts instead of the traditional flare and NPT fitting which can be tightened if found loose.
I know nothing about these quick-connect fittings (quick for the factory assembly line) except they probably need a special tool.
So here I am bleeding trans fluid with no way to check the fluid level to see how much has bled out before I received the car and no way to stop the bleeding. The car shifts right (I think) so the level is probably not dangerously low but I'm treating the car as though it is.
I can actually move the line around so it is loose and there is no way to tighten it.
2 questions:
1. How can this connector be tightened?
2. If the dealer is the solution, what is the likelihood it's cover by the powertrain warranty? I heard reports GM reps turn it down at a General Motors forum website.
Any insight would be appreciated.
2 questions:
