John Robinson
Gone but not forgotten
Back in May of this year I posted about my transmission not downshifting when I pulled the lever into a lower gear. I had some good responses and so I am updating what I have done since then. I have driven the car over 3K with spirited use of the go pedal. Back in Sept. I had the transmission flushed. today when I pulled out of the garage and put the car in gear the shift lever stiffened up and then broke lose with a noticeable noise in the tunnel area. Now here is the weird part the car now has downshift braking when you pull the lever into a lower gear. My thinking is running towards the possibility that something is wrong with either the linkage or cable from the shift lever to the transmission. Has anybody ever replaced that cable and if so what is the job like?
