c4c5specialist
Technical Advisor
HI there,
There is a 22mm fill plug in the side of the transmission.
You need to make sure the transmission fluid temperature is between 80-122 F then start the vehicle.
Place the shifter in EACH gear position and then return to park.
Remove the fill plug, you should see just a drop or 2 dribble out.
If not, it requires fluid till it comes out of the hole.
Allthebest, c4c5
Allthebest, c4c5
