G
Geek's 65
Think my transmission has decided it's time to be rebuilt. 2nd gear is 80/20 that it will work. 3rd gear is 30/70 that it won't. Reverse is 10/90 that it won't and if it does - it's very hard. (Removing the linkage from reverse and shifting it manually - it's very hard.) Little earlier than I had hoped but not unexpected. So you order a kit to rebuild which replaced gaskets, bearings, synchros, and a host of little parts. Any other nuggets of wisdom out there? Get the video that I see advertised? Never done a Muncie but have been in to a couple Ford transmissions.
Any bit of wisdom will be appreciated.
Geek
P.S. Yes I did align the shifter four times and had it checked after the fourth go by "One who knows". Thanks.
Geek
