RV Guy
I had the automatic on my '86 completely rebuilt about 2,000 miles ago. The couple of times that I have stuck my foot all the way in coming off a stop light it seems to hang for just a second just as the tach goes into the red line before it shifts into second.
Having it out for the first time in a while tonight it did just as stated above except that after I stopped for a stop sign I only had first gear. I drove it a mile or so to my destination. It sat for about a hour and when I started back home again I only had first gear. I found a way to coax it into second by shifting into neutral and then back into drive. This worked several times after having to stop. After about five miles it all of a sudden started shifting normal again. Coming off a stop with a slight throttle brought normal shifts right up to 4th. Now that it seems to be working normal I try a little harder acceleration, part throttle, and it shifts just like it should through to top gear. I didn't mash on it thought. I wanted to make sure I got home. Monday, I will call the shop that did the tranny work but in the mean time, any ideas?
