bamaboy
New member
So, the rear end on my '85 is sagging and I order a new set of shocks. I put the first rear shock on and set it back on the garage floor but there is no increase in ride height. I walk to the back of the car and notice the rear wheels have a lot of negative camber. I start to get this bad feeling in my gut so I raise the diver side rear end, crawl under the car and there it is; a cracked and splintering transverse spring. Do I buy a new OEM, other aftermarket, or used spring? What else should I do while I have the rear up in the air?
