Trap speed vs ET
Staten Island, NY
1999 Torch Red Coupe
I went to the track last Saturday, only had one run and I messed it up at that, I bogged it coming off the line, 2.65 60 foot time.
But I ran through the traps at 106.9 MPH, I figure with a decent launch I should be looking at a low 13 second pass - ???
Also, I slid the clutch in from about 2000, way to low. What do you launch at?
Thx
My local strip is at 2600ft. The C5's here run in the 13.9-14.1 area at about 104MPH. My Z06 with drag radials and vararam runs 12.5 @113MPH (12.42 best). I think that low 13's would be optimistic for a stock C5 at this elevation, but maybe it is possible at sea level. The biggest variable will be the launch. Wheelspin is generally bad. A good 60' time would be in the 1.9 second area. I hope that this helps some.
About a year ago in Germany, I ran a 13.8 at 104mph on a 100 degree day. I do not know the elevation. At the time, the only mods I had were a K&N filter with a Z06 air cleaner cover. I launched at 2000 rpm and only had a bit of wheel spin. The track had plenty of rubber on it so traction was not an issue. That was with the stock runcraps.
In a car mag article I read concerning the 2004 corvette, the writer said the best launches for a 1/4 mile were done at 2500 rpm.
The track I go to is at sea level. I figure that if my C4 ran a 13.59 stock, my C5 with 50 more ponies and 200 pounds less weight should do better.
My lack of skill with the 6 speed seems to be the problem. Thanks
I noticed late model Corvettes really take a big hit in performance when it gets hot out. I am going to try 2500 to launch at.
Just remember, an automatic can always produce more consistent shifts. Also, that loooooong throw with the stock shifter is probably good for adding a tenth or 2.
I guess I should add that my car is a 6sp with factory shifter as well.
Sure !!!!
(OH, I will send you the in car vid, and the one of my next pass, showing why you dont speed shift with the traction control off)
When where ? Just dont make it on a day when the track is having an "event" as in hours between passes.
warren s said:
Sure !!!!
heh when ever i make it up there :( it's about 200 miles for me.
cerberus said:
You guys are meaning 2500 in 2nd right?
No, I mean first gear. I launch higher than that- maybe 3500-4000RPM in first. I do my burnout in second, but I launch in first.
warren s said:
13.12 @ 105.24
At Raceway Park tonight. I can hold my head up high now!
Nice run! Congratulations!
I wonder what I would run at sea level. I thought that my elevation cost about 0.3-0.4 seconds. Maybe it is more?
warren s said:
13.12 @ 105.24
You know, he's not called Mad Mic for no reason. :D
Oh Lord- Warren vs. Mad-Mic at the track!
Set your wagers here, folks. I sense this challenge could have the aroma of testosterone hanging about the room.
Um... vids from both sides, please! :D
(I can't wait to see this challenge! Warren's "zen-time" C5 vs. Mad-Mic's "Respect My Ow-Thor-ee-tay!" C4. This could be interesting.)
-Patrick
-Patrick
hehe Warren knows i'm just messing with him! but serious my best run so far back in march was a 13.18 at 105.84 with a 1.85 60' i've done a "few" mods since then but would be a good run!
those guys over on CF want me to come up and make a race before season's end so i'm gonna try and make it :)
new mod list ;)
K&N open air box, MAF descreened, TB Bypassed, 160* T-Stat, Accel Super Coil, 12* degree advance timing, Cut Back AC Delco Rapid Fire plugs gapped at .050 Indexed, TPiS Long Tube Headers, !Air, Air Elim Pulley, !EGR, Crank Pulley, and KBD Targa 3" Mufflers. Hayden Tranny cooler. Stock 1600 rpm stall, 2.59 rear gear on 275/40/17" BF Goodrich Drag Radials.
Refer to this post for pics of my new mods ;)
http://www.corvetteactioncenter.com/forums/showthread.php?t=57197
I need to scan my time slip and post it, I think with differnt tires I could do a slight bit better, my 60 foot time was 2.09 so there was some wheel spin (or clutch slipping) but the LS1 made up for it.
MAC, I think I need to take a trip down to Ceicle raceway, getting a digital cam corder and will need to break it in.
