Bolisk
So, I've recently received my new door panels for my 1970 Corvette.  They are the standard door panels, and they look ok. . .but I'm a little disappointed in quality of some of the elements of the panels.
So, first thing I noticed (which was after I started modifing the panel so I can't return them) was that the decorative cross weaved pad above the arm rest is not nearly as nice as the origionals. It's almost as if the pressing machine did not press hard enough to really make a good mould. The result looks like it's warnout.
The next thing I noticed is that the hole in the ABS for the windcrank. . .is not even close to being centered with the acutal window crank on the door. So I've had to do a lot of cutting of ABS in order to get the hole in the right location.
Next I noticed that the new door pulls do not fully insert into the new panels. Meaning when I put them in the new door panel. . .they dont seat all the way in. . .the hit the ABS plastic before they seat flush with the vynal on the panel surface. The new door pulls do however fit perfectly in the old door panels.
Next the screw holes in the ABS for the door pulls are no where near the correct location for mounting holes in the door pulls or the door it'self.
Lastly. . .I had the manufacturer install the lock plate and the U-trim. Oddly enough. . .the ABS holes were not lined up for that either. . .and the manufacture also seemed to make the appropriate comensations to make sure they were installed correctly. . .THANK GOD. So the hole in the lock plate does line up correctly.
Yes. . .i've tripple checked that these door panels are the correct pannel from my car and door. Yes, my doors are correct for the car. However, my car is a Feb built 70. . .is there a possibility that the doors are actually 69?. . .and the don't line up right.
Next when I temporarily hang the door panel on the door, I noticed that the upper left and right screw holes don't line up with the origional holes made in the actual door frame. The one on the left is an 3/4 of an inch too high, and the one on the right is approximatly a half inch up and to the right.
Soo. . .when I closely compare the too door panels, the new one has a nice crisp 90 degree shoulder in how the top part of the panel attaches to the top of the door. The origional pannel on the other hand. . .appears to have been collaped so that the pannel was hanign down a bit. This seems to explain why the screw holes don't line up. . .it's almost as if someone in the factory smashed down on the top of the pannel to the door. . .effectivly breaking the fiberboad/fiberglass origional backing. . .causing the mounting holes to be drilled slightly off.
So the first question is. . .should I just drill new screw holes (for the upper right and left mounting screws. . .i.e. the ones that go through the door). . . because there is no hope of getting them to line up with the origional holes?
Next, should I just cut out the ABS in the door pull hole completely. . .so that they seat all the way?
The next question is. . .is all of this normal! Has anyone else seen these problems with door pannels. I'm rather dissapointed so far.
My last question is, how in the hell do I get the pannel to stick to the door frame. After I've mounted all the clips and screwed everything up. . .the forward edge of the pannel (by the hindge) does not want to stay attached to the door. . .and those pannel clips (the plastic velcro type things) don't seem to hold. Almost as of the pannel is not shaped correctly.
Any help / suggestions would be great.
Best Regards,
Bolisk
Best Regards,
Bolisk
 hnoes
hnoes
