TRW spring good or bad
  • Thread starter Thread starter OakieVett
O
OakieVett
I just purchased the 340lb TRW spring and am hearing folks say the car will sit too high. Anyone install one and are happy with it.
Can you return and get a refund for the springs?
I had heard something similar, so I decided to utilize 550 lb Coil Springs offerred by VB&P... it was a relatively simple install. With the engine was reinstalled, the loaded springs sit at a perfect height.
I've had one on mine since 1990ish and aside from having to install longer spring bolts to restore correct ride height, it's been trouble free.
I doubt I would go back to the steel spring except for NCRS judging.
Did you use the 8" bolts
