S
sscam69
Pretty much what the post says.
I am having problems with a ping in the number 6 cylinder of my engine. I really don't know what it could be.
I have set the ignition timing at 16 BDC @idle and I am running @28deg mechanical (with soft springs) and 51@part throttle. The timing seems to be OK.
As some of you know or don't know I just installed a cam shaft but I figured If I installed it wrong then I would be getting pinging from all over the place. I have the stock heads with 78cc chambers and pistons with valve reliefs and then some. I am guess my CR is about ~9:1-~8.x:1. I am running 91 octane in the tank (just filled the other day).
I pulled the spark plugs from the passenger side and the #6 plug was a really light brown, close to white. Then I pulled the #4 cylinder plug and was a medium to dark brown.
I have checked the wires and pulled the wire to the #6 to see if it was firing. It was.
It could be a defective spark plug. BTW their all new plugs.
I am going to swap the spark plugs with another cylinder to see if its the spark plug causing the problem. Oh BTW the spark plugs are Bosch Platinum (single prong, don't believe in that 4 prong:eyerole jaz).
Then I am going to check if I wired the HEI to the right cylinders. I checked it twice before I fired the engine and it was running fine. The problem has seemed to of have developed.
I am going to check all the external equipment first if this does not work out I am going to pull the head and see if there is nothing wrong. The drivers side is just fine.:confused
What do you guys think it could be?
What do you think about my course of action?
any input would be greatly appreciated!
Frank
Frank
