I just got a digital tach & dwell meter, never used one before but it seems simple enough. The emissions sticker on my 72 LT-1 says the dwell should be at 30 degrees.
My question is at what RPM's should I be measuring the dwell?
These are the readings I got:
at 980 RPM = 31.2 degrees
at 1500 RPM = 30.7 degrees
at 1600 RPM = 30.2 degrees
Am I OK? Are these readings close enough to spec?
I also made sure to plug the vac hose when I took the readings...
