J
john davis
I have a 75 with edelbrock6090 heads dynomax headers comp 268h cam 700r4 tranny with 3.70 gears curently running a edelbrock performer rpm intake with edelbrock 750 carb I would like to switch over to tpi a mechanic friend of mine has a set up off of a 88 camaro with 60000 miles on it. everything is there except fuel pump what would be the best way to solve fuel pump set up can I get one to go in the tank or will I have to use an frame mounted variety if so what would be a good pump and cost and how much psi would i need?
