Question: Turn Signal
gmhowe
glendale, az
1985 4+3 black cpe & 96 LT1 CE
On my 96 CE LT1 my right turn signal just stays on when I turn it on, is there a Solenoid for that ? and where is it located at . The left one is fine so could it just be the bulb ?
Thanx
Gordon
gmhowe, On my 1989, the turn flasher is located on the passenger side, behind the instrument panel. I remember seeing it when swapping out the ECM. Only one turn flasher that is used for both right and left turn indicators. What happens when you turn on the emergency flasher?
They all work except for the inside right one, just finishing replacing the bulb and all better now. According to the FSM there is only one flasher.
any way thanx
Gordon:w
Thanx
Gordon
Chances are it's just the bulb. Mine did the same thing; It was front turn signal bulb.
Bulb alright the inside right side in the back, all better now easy fix on the 96 just undo the screws and pop the lens out, much better then my 85
Gordon
