maxrevs85
I was in the process of removing the battery via the side panel and I needed to turn the wheel alittle for clearance to the screw on the wheel lip. I didnt bother to start the car ,I just reached in the door and turned the steering wheel . When I did this the wheel slipped a little and made a noise like splines slipping. I varified that the shaft was turning. It only slipped about an inch looking at the steering wheel . When I turned it back it did the same thing before the wheels turned. PLEASE tell me this is normal when you turn the steering wheel without the motor running.
Shouldnt turn the wheel when the motor's not running right ?
Dave
Dave
