Peer81
Hello everybody,
In my quest to change the ECM to a '88 1228079 ECM I was checking all the wires are the ECM because the ECM terminal identification on Fig. 6E1-46 is incorrect! BUT my smallest ECM connector has one white wire more (at the M terminal) then all the wiring harness diagrams I have are showing. So can somebody check for me if they also have the white wire at Terminal M? It's a thick wire maybe 1.0 or more! In this 2006 picture I had when I had the ECM wiring out of the car you can see the wire as the lowest wire!
Second question of course is what does it do? I looked at all the connectors in the engine bay but no white wire overthere (accept for the white wire going to the ESP but that is on terminal 12 at the ECM big connector). So it could be that it is connected to something under the center console but I checked the pictures I have on the wiring under there and also no white wire from the ECM harness. Also the '88 service manual I have shows that terminal M is not used.
If somebody could take a look if the also have this wire. It should be in the harness going to the top connector to the ECM. And if somebody knows what it does I sure would like to know
Thanks!
Greetings Peter
Thanks!
Greetings Peter
