- Moderator
- #1
vetteboy86
I purchased a new fuel pressure guage, and it works much better. For some reason I think that pintle on the schrader valve is off center, because the old guage just would not give me a good steady reading.
Right now the Fuel pressure is set at 46 with the vacuum line unplugged. I also put a heated O2 sensor on the car. Before the car was running lean all the time per the EASE software I am using. The O2 voltage hardly rose above 200 millivolts.
WIth the heated O2 sensor on the car, the car transistions from rich to lean normally now. The O2 sensor voltage now goes from 100 mV to 900 mV like it should. I also do not have any more spark knock, and the car pulls incredibly harder. I think I am safe for now, I notice it does pull some timing right when i get on it, but I can work that out.
Just wanted to let everyone know of the situation, and thanks for all the help.
